I building a pair of JV60 speakers from Jaycar that I am building for the Jaycar store I work at, basically bought the boxes and drivers, everything else i will build myself, also having external crossovers in large jiffy box for build and tuning ease.
Not sure on what crossover design as yet but have found reference to the crossover schematic (2.5 way) from the original kit that might end up basing it off,
http://2.bp.blogspot.com/_W1x0C8rk2XA/TFLagFr5aTI/AAAAAAAAAKc/uLnHEq-Ykgg/s1600/XO_2.jpg
As for now I have 6 db crossovers on all drivers, 3mh on the woofer (bottom driver) no inductor on the mid/woofer
(top driver) and two 3.3uf poly caps in parallel for tweeter (so sort of a poor man 2.5 way crossover for now and with a 4 ohm impedance at the speaker terminals).
First thing I'm going to build proceeding the initial build is to seal the enclosure, make a thin MDF board to build the crossovers on and get the impedance eq/zobels designed for each driver, stay tuned
Here are some pics (go to link)
Note i don't have bass ports yet.
ImageShack Album - 6 images
I was considering taking on this project, so I look forward to your posts.
Have you seen the Red Spade Blog (Red Spade Audio: JV60 upgrades), he built a new crossover and enclosure.
Update:
- Installed bass ports
- Designed 2 way 6db damped two way crossover
- integrated baffle step (still fiddling)
- Soldered up Xover ready
See new photos: crossover shematic/pic/bass ports installed (changed host):
Pictures by robywan_2009 - Photobucket
Peace off
Toby
Peace off
Toby
