I built an isobarik sub with two old Cerwin Vega W15P PA woofers,
Main reason was I already had the box (3.85 cubic feet) had two woofers rated at 300 watts RMS 4 ohms each and a Carver amp to punch up to 750 watts into 8 ohms. Did the isobarik trick for 7.3 cubic feet (it's Vas rating) it handles the Carver since the two are wired in series and to further save space, threw an 18" passive radiator on the back. Extended the box sides about 7 inches and built a two piece grill.
I like the Iso-PR setup, it handles twice the power to make up for the sensitivity loss, is reasonable in size, sounds cleaner since it's push/pull and the passive is easily tuned to 21 Hz without giant ports or chuffing.
The front to back thing does not work well since you have a much larger area of air coupling the two woofers...the more air the lower your crossover needs to be. Others have mentioned the voice coils getting hot since it is in such a small space. It also uses a larger enclosure which goes against the point of iso loading.
The other option if you HAVE to see some form of cone is to use a passive radiator--it is very confusing to people that see a clamshell isobarik and just adds to the mayhem with the passive thrown in for good measure. With the grills in place, it looks like a normal box.
