Is this sub going to outperform SVS PB12-NSD ?
Judging from the graphs below ... would the sub I wanna build outperform the PB12-NSD sub made by SVS ?
Its a 120 liter box tuned to 20hz using a 500watt bash amp with PEQ at 80hz -2db and static gain +3db with high pass filter @15hz
Transfer Magnitude
SPL
Max SPL
[img="http://img185.imageshack.us/i/maxspl.png"]Imageshack - maxspl.png[/img]
Amp load
Cone excursion
Group Delay
Transfer Function Phase
I dn't know if it is overkill, but you have forgotten to take room gain into account. I shoot for a response that starts declining at 50-80 hz and am looking for the lowest F10 (f3 is meaningless)
Add a 3-6 dB per octave uplift with a corner at ~70 hz and see where your curve ends up.
dave
..If this is for both you want the first one, and something to customize the EQ.
In this enclosure: Use any Sub-amp > 160W and EQ is not necessary as this enclosure should be stuffed with wool like an TL to half-ways down the line, counted from the rear of the driver:
b🙂
