I'm wiring up a power supply for an amp and have a question about wiring the IEC inlet.
The connectors on the back are sized perfectly to fit 0.250 female slip-on connectors. Should I ignore these and solder directly to the spades or would using a female connector be safe? I'm not looking to cut corners, just wondering.
Thanks in advance.
Thanks in advance.
I think it is as safe as soldering, or even much safe (because solder can melt).
I just add that it is better to add additional isolation to those open connectors. I use specilised silicone ones, but anything will be good (heat shrink etc).
Oh, I see it was said yet.
Just sleeve them with heat shrink after fitting, then all bare metal is hidden. Just make life easier during those slipped with a metal tool when powered up moments.
Or get shrouded connectors in the first place - you can buy the shrouds separately, flexible transparent rubber boots basically. This sort of thing: Flexible PVC Covers For Non-Insulated Terminals | 12 Volt Planet
Basically there should not be exposed mains metal inside a box that can accidentally be touched.
Btw, the terminals you've been showing in your 1st posting aren't good ones, as they don't grasp the cable insulation.Thanks all. Crimped on some good quality terminals and used some adhesive lined 3:1 heat-shrink tubing.
Best regards!
- Design & Build
- Construction Tips
- Is This Safe?
