I realy dont have any knowledge in power supply. I want to feed a 12 VDC amplifier (4x100 watts - 4 ohms) with this Omron power supply. The dealer suggested me to buy the 600 watts - 50 amp.
Can you help me to make an intelligent choice.
Thank you.
Omron S8VM 60012C - Price= $325 CAN
Data sheet
http://www.ia.omron.com/data_pdf/data_sheet/s8vm_dsheet_csm140.pdf
Power rating 600 W
Input Voltage
100 to 240 VAC
Frequency
50/60 Hz
Current 100-V input
8.0 A max. (5 V)
8.3 A max. (12 V, 15 V, and 24 V)
Current 200-V input 4
.0 A max. (5 V)
4.2 A max. (12 V, 15 V, and 24 V)
Power factor
100-V input = 0.98 min.
200-V input = 0.93 min.
Leakage
100-V input 0.4 mA
200-V input 0.75 mA max.
Inrush current
100-V input 20 A max.
200-V input 40 A max.
Output Voltage adjustment range
-20% to 20% (with V. ADJ)
Ripple 3.8% (p-p) max. (5 V), 2.0% (p-p) max. (12 V), 2.0% (p-p) max. (15 V), 1.25% (p-p) max. (24 V), (at rated input/output voltage)
Input variation influence 0.4% max. (at 85 to 264 VAC input, 100%)
Load variation influence
(rated input voltage) 0.6% max. (with rated input, 0 to 100% load)
Temperature variation
influence 0.02%/°C max.
Startup time
1,000 ms max. (at rated input/output voltage)
Hold time
20 ms typ. (15 ms min.) (at rated input/output voltage)
Additional functions
Overload protection
Overvoltage protection
Overheat protection
Power failure alarm indication
Power failure alarm output
Series operation
Parallel operation
Remote sensing function
Remote control function
Storage temperature -25 to 65°C
Ambient operating
humidity 30% to 85% (Storage humidity: 25% to 90%)
Thank you.
Data sheet
Power rating 600 W
Input Voltage
100 to 240 VAC
Frequency
50/60 Hz
Current 100-V input
8.0 A max. (5 V)
.0 A max. (5 V)
Power factor
Leakage
100-V input 0.4 mA
Inrush current
Startup time
Hold time
Overload protection
Overheat protection
Series operation
Parallel operation
Ambient operating
would you get better performance by buying two, two channel mains powered amplifiers to give you your target 100W into 4ohms?
I wouldn't pay to down convert to 12Vdc, to up convert to ~30Vac, to convert back to ~40Vdc
I'm a car audio fan and since I come on this forum I plan to install a setup in my living room.
I already have the enclosures for witch I have posted a thread.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=114851
I need advise for the speakers choice.
My amplifier is an Orion 8004 and the head unit an Eclipse CD7000.
To power this setup I need a power supply. But as I said I dont have any knowledge about PS and I need help. I found this one (Omron) and I want to know if it is appropriate.
