What kind of amp are you making? Quasi? What power level into what load Z? If you intend to make a complementary amp, you will need a P-ch of relatively the same conductance. Is this amp to be a common drain or a common source output stage? There is quite a difference. Class A or what? Is it that you already have these components or are you deciding on which components of these type to obtain?
BUT.....
Details are needed to determine a proper driving circuit.
BUT.....
BUT.....
actually i am looking for 600W @ 4E and near bout 1000W @ 2E. i am looking for quasi design and i want the amp to be a class AB with rail switching ie class H .......... can these details help in designing the driving circuit ......
regards
phoenix
regards
phoenix
High gate capacitance is not the problem.
Do you have a proper conceptual schematic for your class-H ?
ok workhorse as u say then how how about LEGENDSTAGE MK2 or Quasor from DR Bora. But may i ask why is B500 not a good ideaB500 using mosfets in quasi-complementary is not correct way
regards
Sekhar
I believe Workhorse designs such high power amps for a living. He certainly knows what he is talking about.
What the OP asks for is not simple or cheap, even without limited choice of output devices. That is a lot of power, and a lot of heat. For 600W into 4 ohms, Class D is a far more sensible solution.
workhorse why dont u suggest a design ..........
regards
sekhar
You already have apex's H900 on the forum built by many.
hi workhorse
greetings do you any high power amplifier kits for sale can anthony holtons
av 1000 or av800 be made into h class have made both have few ready pcbs
for experiment do you sell ready made amplifiers sorry for asking you again
today saw zypher amp site the ALPHA AMPLIFIER is it your creation
thanking you
andrew lebon
thanking you
andrew lebon
hi workhorse
thanking you
andrew lebon
Have a look,
I dont know about holton's av1000/800 so can't comment.
this one is ready to buy:
http://www.diyaudio.com/forums/solid-state/177120-professional-class-h-amplifier-2kw.html
Here is the pcb: pic
- IRFPS37N50A or IRFBA22N50A as o/p devices
