The IRAUDAMP7D reference design uses the 5-pin dual MOSFETs. The reference design shows scalability upto 250Wrms/8E.
I was wondering, if replacing the IRFI4020H-117P in the AMP7D-200 with one pair of IRFB4127 will enable 500Wrms/4E, 1000Wrms/2E and 1000Wrms/8E-BTL options.
If this has already been tried, are there any mods to the AMP7D-200 design, except maybe the current limit setting?
Can IRS2092 drive only one pair of IRFB4127 directly or do I need to use a gate driver?
As always, thanks in advance for your time and efforts in sharing your rich experience!!
IRAUDAMP7D with one pair of IRFB4127
Thanks for your reply.
I will add buffers/ gate drivers similar to that outlined in IRAUDAMP9.
Based on the low (4 times) RdsON and almost 6 times the current capacity of IRFI4020H-117P, do you think that power levels that I have estimated can be met by using only one pair of IRFI4127?
Thanks again!!
Thanks again!!
