Hi all, I'm hoping someone can give me some suggestions for solving a problem with my Decware SE84B.
I've had it for some time and recently it picked up an intermittent buzz -- it sounds more crackly than 60hz ground buzz, but similar. It's loud enough to be heard through quieter music. Duration is usually a minute or so, though sometimes longer. It seems to have no connection to whether the amp is warmed up or not. When the sound isn't there, its dead silent.
If I pull the input cables while it's happening, there's no change (so it's def the amp). If both output tubes are removed, it doesn't happen. If the input tube is pulled, it does happen. I've replaced both output tubes, which made no difference.
What I am looking for is suggestions as to where you'd start trying to diagnose the problem. The amp's typology is pretty dang simple, and the parts used in it are super robust. Seems like it's too young for things like capacitor failure etc.
