Interesting and counter-intuitive: an example of dithering effect on auditory system
Contrary to a common belief, the presence of white noise can actually unmask sounds:
Good noise, bad noise: White noise improves hearing -- ScienceDaily
Does this mean that "privacy" measures used in open-space offices have the opposite effect?
Maybe, for a certain range of levels, but if the masking noise is strong enough, probably not.
Is "strong enough" going to be problematic or intrusive is another interesting question
Hearing loss
My results
Disabled Account
Joined 2017
As far as I know about hearing, there are mainly two types: selective and analythical.
The former makes it possible to 'filter out' surrounding noises, the latter includes everything into a 'frequency response analysis'. Adding (coloured) noise to sound will have different effects and results on these types of hearing.
PRR
Joined 2003
That's a novel thesis. With direct application to many hearing questions. If you can show a valid basis, you should submit a paper to the audiology publications.
