I'm building some interconnects based on a design by platenspeler. They are working out really well - so I built another pair with the silver I had left. Now, one of these is for my CD-PRO2 CD player. I want to attenuate them by 12dB. Does anyone know the calculation to design such a network?
Thanks,
Gaz
Thanks,
Gaz
You want to attentuate the signal by a resistor network, right?
12 dB would be something around a factor of 4 (voltage factor=10^(x dB/20)) so you basically want a quarter of the original signal.
Cheers
Jens
Cheers
Jens
Thanks,
I just needed my brain jump starting. I got values for R1 to be 3k and R2 to be 1k in normal potential divider cofiguration.
Thanks again,
Gaz
Thanks again,
Gaz
