Integrating head amp into system
Hi all,
I'm building an integrated SS amplifier and intend, at the construction stage, to make integration of a separate-chassis SS headphone amplifier as easy as possible.
How is switching of the source to the inputs of a separate headphone amplifier 'usually' done? Are these commonly taken from the output of the pre-amp?
I am thinking of making the pre/power sections (which will be in the same casing) able to be used separately via some sort of short external jumper arrangement on the back panel.
Cheers
Stuey
Hmmm...just had a rethink when not under the influence of Corona and realised that it'd probably be better to run the headphone amp from line level, eliminating the pre-amp circuitry from the equation. Of course, most headphone amps would be designed to be driven directly.
A tape loop seems to be the way, but then you lose the control functionality (volume at least). Still, that's easy to implement on the headphone amp.
Onward...
Cheers
Stuey
