There has been a lot of talk about the First Watt M2 amp by Nelson Pass.
I have become very curious and interested in trying some kind of very simple amp based on an autoformer. The M2 is a little to complex for me at the moment. I would love to build one, even though I have my ideas about possible changes I would make (probably only making it much worse sounding).
The most simple amp based on an autoformer of some kind I could Image is a simple source follower. I wish I had a fist full of Ixys depletion mode fets, but a cheap IRFP150 salvaged from an earlier project will have to do.
This is where I got with the parts I had at home.
I will try a Cree SiC fet soon.
The air-cored autoformer is quite cheap and easy to build. It is 600 turns of 1,5 mm2 electric wire, bifilar wound around a PVC-pipe between two pieces of particle board.
I got the inductance to about 30 mH in an online calculator Coil Inductance Calculator - 66pacific.com
https://youtu.be/Tg-V3i0IUB0
I get a very respectable bass from the amp despite the low inductance. I plan on use two of these for my Faital Pro 3FE20 wide band driver, so it will not have to deal with much below 300 Hz. Today I wanted to test the amp fullrange to see what it could do.
Wih the large and very powerful BIBs I don't need a lot of power from the amp. I could be quite happy with this simple amp, even though I would probably wind on another 200 turns if I wanted to use it fullrange as my main amp.
I guess a nice preamp is needed. The amp has a voltage gain of only 0,47 X, since the autoformer is center tapped to the speaker.
Johannes
Johannes
