Use the biquad calculator tab in your advanced plugin to generate an arbitrary set of coefficients so you can see the proper format.
Then use the coefficients generated by the spreadsheet (corrected to the proper order/format) and paste those to the PEQ area on the desired EQ band.
Dave.
