Unity gain input transformers can be used to isolate two grounded through the safety pin of the power cord devices, to eliminate ground loop hum. Band use "DI" units for this, which are op amp based, but input transformers are a more expensive solution. Put a 1/4 phone plug and in and jack out, and see how they sound between keyboard and PA amp in a band situation.
