input stage current required to drive output mosfets?
my output stage is 2 paralleled mosfets with 1400pF of input cap each.
they are operated in source follower config.
how much current should be previous stage operate at to allow decent HF response and minimal distortion?
My input stage is a hybrid u-follower and trying to judge at what current to run it at....
Thanks!
ok ...
the output stage is 2 mosfets... maybe irfp140n's.
run at 25v and 1.5A each... source follower
connected to 8 ohm load thru 1:1 output transformer.
so max frequency is probably 30-40Khz with swing up to PS voltage.
gfs = 11
input cap is 1400pF
output cap is 330pF
reverse transfer cap is 170pF
does this help?
wondering if a 18mA input stage will cut it..
well...
actually wanted to use a ECC99 tube with mosfet source follower as load... i.e. u-follower.
18mA through tube... can run u-follower higher if wanted too... see alan kimmels stuff.
question is what current is good.. is 18mA good or should I run it at 50mA?
my 300v PS is good to 100mA.
