signal out or in....
Hey Skippy, thanks for the reply, I think I understand things better now. What I need is a CD player so like you said maybe a CD/DVD. Now, The Power amp I made has a one stage 12AX7, and a single ended EL84 (just one) using a 25 watt tranny plenty loud drives a 12 speaker good. What that has for a input sensitivity I don't know but it plays my old cheap tape deck fine.
What I mean about (digitial output) is this, when I was shoping for that CD player, in the back where the RCA output jacks are some said digitial others had both digitial or analog output RCA jacks. My tube power amp that I made is point to point. What type of CD deck will this be compatable with, I think you did answear that and if I understand you right it was Analog. Can I get this CD/DVD in Analog or does that converter chip you mention take care of that??
Thanks,
Rob
