Hello Everyone,
I have an Infocus X1 which was working fine until the lamp blew. I replaced the lamp with a brand new lamp and now the pj will work only intermittently. If I open the lamp door and press the safety switch the lamp will sometimes work. Same thing if I disconnect the bulb and then reconnect closing the lamp door. When it doesn't work all fans appear to run, get green light then 3 flashing red leds. Could this be a safety switch problem, ballast/power supply ECA problem? Not really sure what's up and now I've got a new bulb with a pj that doesn't want to cooperate. Any help would be appreciated.
