I have a pair of these drivers that have sat in a closet for 4 years and I was wondering if they would
both be suitable for use in a double 12 tapped horn:
Infinity reference 1230w 12"
Sens. 2.83v@1m: 90 db
P.handling: 300 wrms
Imp: 4 ohms
V.C.: 2"
Re: 3.4 ohms
Le :2.54 mH
Sd: 82.48 in2
BL: 14.63(tm)
Vas: 2.78 cu.ft
Mms: 174.1 grams
Mmd: 167.15 grams
Cms: 195.4
Fs: 27.27 hz
Qms:6.14
Qes: 0.47
Qts: 0.44
Xmax: 12.25 mm
I think the bl may be a it low?
Would they be better suited for a HT sub or for music??
Any help or tips would be greatly appreciated as I don't have access to a computer for quite a while.
And no I'm not going to jail
Imp: 4 ohms
V.C.: 2"
Re: 3.4 ohms
Le :2.54 mH
Sd: 82.48 in2
BL: 14.63(tm)
Vas: 2.78 cu.ft
Mms: 174.1 grams
Mmd: 167.15 grams
Cms: 195.4
Fs: 27.27 hz
Qms:6.14
Qes: 0.47
Qts: 0.44
Xmax: 12.25 mm
