Improving on DAC output chips
My pcm2704 + AD1955 DAC has three OP275s at the output, and as I am planning some upgrades to it, I wonder which ICs to try on the sockets.
OPA627 are my first choice and already ordered them from eBay. Let's hope they are not fakes.
Another option would be the LM4562. Same thing with the seller. As I can not buy from Mouser or Digikey, eBay has to be my source. Any serious reliable vendor there?
What other alternatives to try for the ICs?
OPA627 are my first choice and already ordered them from eBay. Let's hope they are not fakes. Another option would be the LM4562. Same thing with the seller. As I can not buy from Mouser or Digikey, eBay has to be my source. Any serious reliable vendor there?
NO!!
Unless you patd some serious $$$ (>$20 EACH), those OPA627s are almost GUARANTEED to be fakes!!
Fortunately I have some 627s that I got as samples directly from BB a long time ago, when manufacturers still supplied samples for free.
Pity at the time I asked for several more 637s, instead of 627s, and the 37s need a minimum gain of 5, which is not the case on this output.
As this DAC has an unbalancing trio, there is no gain.
I am not sure about the LM6172, which I would love to use too, and I also have a few. The 6172, and other similar National video buffers, seemed to do marvels on Philips DACs. But I don't remember what you had to add if you used them so as not to oscillate. I did try them on a Sony CD player I modified, and the sound was marvelous.
Believe it or not, different economies have varying scales of value, so the US dollar value isn't always the first indicator of a legitimate component.
There is a simple ohms test that can be performed on the opa627, can search for that.
For the price I had paid, it didn't seem worth trying too many other sand-based op amps.
All my stuff has burson discretes now, and I will try the eBay discrete op amps next if/when I need any that is.
Before rolling opamps, spend some time optimizing the power supply cleanliness. All opamps benefit from this.
Then swap out your OP275s next to the AD1955 with LM6172s and replace the feedback capacitors with 4.7pF.
For the supplies, I should trying properly arranged 317/337 first. And then Jung regulators.
About the LM6172, which capacitor you suggest to replace? C40-41 and C42-C43 for 4.7pF? Isn't that a bit too different?
Which discrete opamp?
Sorry, which test is that to test if 627 is fake or not?
