Namely I need help in making sure I'm doing just 3 things correct... I have the BrianGT boards
I have all the resistors for output matching etc etc
3 questions.... any thing helpful would be great
1. The OG from each board (in pairs of 2 paralleled per channel) is the Output ground so I assume I parallel these to the - terminal of the output banana jacks?
2. The AC1 and AC2 one has a line over it the other doesn't... I'm assuming the line over it means neutral correct?
MOST IMPORTANT QUESTION:
3. I have a transformer with dual primaries and secondaries... I understand perfectly that the dual secondaries are split to each board etc (one for the AC1 other for the AC2) ... but with dual primaries to I need to hook both primaries to the 115V AC? or will just one suffice? they can both be on the same AC jack correct?
thanks in advance
I'll post pics of this in a few hrs
thanks in advance
