I'm about to move into an appartment and I'll need a little more low end than I have in my room I think. I already have a pair of older towers (not sure what brand) with a 12" woofer and 10" PR in each one. These are good for movies and the like, but for party music they're a bit lacking. I'm looking at grabbing a single 12 or 15 that I can amp off one of Parts Express's plate amps and stick in a non-intrusive box. The average home subwoofer enclosure would be fine, maybe a little bigger. I dont' want to do any complex designs. I may port it, but I'll probably run with a sealed enclosure. I'm also thinking on a college budget here. Try to keep it cheap, but not poor quality. What do you suggest?
thanks!
thanks!
Tuba's... perhaps a Tuba 18?
http://www.billfitzmaurice.com/plan...id/11?osCsid=3fcc40357cd8a3ff844343a2bc199257
I'm guessing that is the cost of the plans right?
I may consider that, but I don't want to have something that's complicated to build. My wood working tools are limited, so complicated angles and the like will be a bit difficult. How hard is that thing to build?
adire
www.adireaudio.com
the tempest,,, aaahhh 150 bucks, and 90 watts will make it hit 145 db at 30 hertz in sealed box in a car,,,,
this sub will blow everyone in your party away and you wont need a big amp to do it,, ported will give you extreme output, but sealed is nice,,,,
thanks, jaden
www.adireaudio.com
thanks, jaden
I have an old skill saw in the garage and I use my Dremel Advantage as a router all the time. I have the attachment for it and all. I'm really not the best with wood, so I don't want to have to build something too complicated. I've always felt more comfortable working with fiberglass (which I still may do for this little project)
I completly forgot about the tempest. It's said to be one hell of a sub,but I haven't heard it. Are there any cheaper subs that will compare?
Re: adire
you might need a little more than 90 watts to hit 145...
- Subwoofers
- I'm looking for a good Bang for the Buck Sub
