Ok, i'm going in head first, into the world of tubes. I thought its about time i tried building an amp out of thermionic valves as i've tried everything else. I started my amp building passion building classD amps and i must say i'm rarther impressed by the sound of those beasts. After that i tried a very basic ClassA design, it used very few components and it sounded really good ( my best sound to date ). The only drawback of that amp was it was so basic the bias voltage was set by a simple preset and the overall output power was only 12 watts. I then spent ages developing a push pull classA with all the trimmings, capable of 50W in A then up to 200 A/B. It was ultra low in measured distortion and noise, based on diff input with large amounts of NFB and massive open loop gain. It was supposed to be my master peice but i was always dissapointed with the sound. I'm convinced that the diff input and masses of negative feedback were ruining the sound. As a result i've now shelved the project and i'm going to try out these mysterious peices of glass. I must confess my basic instincts tell me a hybrid amp with valve front end and mosfet follower for output is gonna sound rubbish, especially since i like my amps totally transparent with no coloring. I'm hoping to be pleasently supprised.
Anyway i've never used a valve before, i know the general theory of operation but i have a few questions. I was gonna experiment with an old valve i found rattling around in my farthers draw but i managed to break it before even powering it up LOL.
I don't like high voltages much so will a valve, an ECC83 for example work at voltages as low as 60V?
If they will what effect on the linearity will this low voltage operation have?
Are there any problems in using an ECC83 for a current source?
How do valves REALLY sound? can i get clarity, transparency and detail from them as i've seen a few ppl spend ages building stunning amps spending loads of money and time on them just to say they sound 'not as good as i'd like', or 'i'll grow to love the sound'.
My master plan is to build a dual stage single ended classA input out of two ECC83 triodes ( one half for CC and the other for volt gain ) and simply run that into a heavily biased classA/B FET voltage follower for the output. This should get rid of the output transformer, and the supply transformer can be a simple 0-30-0-30 tordial. With this i can get a good +-40V for the fet output stage, and use a doubler across the 80v to give me 160v for the valve anode HT.6.3 heater voltage from a 7805 and a few diodes under its reference. If the amp sounds any good i'll refine the design and use it. If it sounds really bad from the start then i'll scrap it and go back to full solid state. Does any body see any unforseen trouble ahead with my idea on this hybrid amp?
Leigh
Leigh
