IIYAMA Pro Lite 38A ANY GOOD
iiYAMA 15" LCD Monitor Color (BLACK), Model# PROLITE 3819UT/-BK
Features:
Signal Input: DVI-I+D-Sub
Video Bandwdith: 80MHz
Horizontal Frequency: 31-60KHz
Vertical Frequency: 56-75Hz
H-Vewing angle: 120
V-Viewing angle: 100
Response Time(msec): 30
Luminance/Contrast: 250/300
Max Resolution: 1024X768
Emmission Standards: TCO99/95
Sync on Green: Yes
Input Connector, DVI and D-Sub VGA
Sounds like a decent monitor. Now the question is can it be used for projection?
I have dismantled the monitor and found it really easy to do so, the only problem with the panel is that it is connected by a rather short ribbon cable to the board so needs mounting right next to it. I hava also remouted it in the monitor frame to provent damage and placed it on top of my ohp. All i need to do now is widen the ohp lid to show more of the panel. The picture quality is top notch. though i keep thinking of building a diy jobby with the bits. and a bigger bulb.
