Hi
I´m looking for Icepower 125ASX2 boards. Are these from Ebay reliables?
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR1.TRC0.A0.H0.TRS0&_nkw=ICE125ASX2+&_sacat=0
Thank you for advise.
The modules themselves are fairly reliable.
They are designed as professional sound reinforcement building blocks so made to take a pounding, although perhaps not up to "audiophile" standards for the living room. Some say they're a bit lacking in low bass, although I've seen no evidence of that. Also, check the spec sheets, some of the higher power modules are only rated for maximum power for very short duration... in minutes... before overheating.
I can't vouch for the build quality of the pre-assembled amps on EBay, etc. But PS Audio is using them in their Stellar and Sprout lines with good success.
I recently found out that PartsExpress carries a good variety of IcePower modules and wiring harnesses: Icepower - Parts Express Ships Fast and Ships Free.
I picked up a few 50ASX2s from another forum member a few years ago and they work great with KEF LS50s. Instead of trying to make a nice enclosure, I just purchased some kits from this site which went together very easily and look quite nice: ghentaudio --- ICEpower 50ASX2 Stereo Case-kit
These are very neutral sounding amps. They will work as they come, but are not really finished, for universal operation you should add an input buffer.
If you ignore this fact, the resulting sound depends very much on the pre-amp you use. While they will sound great with a strong, active driver / buffer, a passive pre is the worst you can do to them.
This explains the different impressions and opinions about them. You find ICE modules in some very expensive high end amps, as well as in active loudspeakers, monitors and PA.
So it depends on the way you implement them into your system what you will get. The 50ASX2 got some negative critic they do not deserve, as they often fail if used in bridged configuration with too low load resistance. TEAC sold an amp based on them too, this was know to cause all kinds of problems, which where not the fault of the ICE modules. Just a very bad implementation by Teac.
While the 50/125SX2 should be driven single ended, there are the amps of the 250/500/1000 line, that have to be driven symmetrically to give best performance.
Unless, it turns out, you live in Canada where they only accept PayPal and charge you for the customs clearances.
I hope I do not have problems with mine... I am setting them up as balanced, and driving them from my Yamaha cxa5100 feeding an Xilica xp4080 crossover.These are very neutral sounding amps. They will work as they come, but are not really finished, for universal operation you should add an input buffer.
If you bridge an amp and run it on a sub 4 Ohm load, the load seen by critical components is less than two ohm. That may overload the 50SX2 and make it´s power supply give up.
As this is often ignored, some fail. Then, people too stupid to drive something right, blame the ICE module.
Used as supposed, they will last, as these are very well designed amps. Some of the best on the market, I could add.
The price of n 125ASX2 board at profusion.plc is about twice the price of an Ebay board coming from Hong Kong. Is it really the same board ??
I can confirm, 50 ASX2 baord are very good sounding with a buffer based on LME49710
I've build a four channel amp like this one :
Past projects: 6-channel ICEpower50ASX amp | theslowdiyer
BR,
Pascal
BR,
Pascal
It's probably the same board. Made by ICEPower in Denmark.
The cheapest, ready made board, where no fake chips are used, if you need a symmetric driver is probably this one:
SparkFun THAT 1646 OutSmarts Breakout - BOB-14003 - SparkFun Electronics
All of the boards listed on American epay were said to be for 220v, and shipping from the U.S.
How would you get one that’s made to work in North America?
According to the ICEPower website the ones with built in supplies (ASX series) have selectable mains voltage.
- Class D
- Icepower from Ebay, Aliexpress, etc. ?
