IcePower 200AS2 vs 100AS2 chipset...
They sound pretty much the same, other than the 3255 having more power output. So the 200 sounds much better if more output is needed. The difference in price is so small that unless just using them for tweeters in an active system, better to just go for the 200's. They both share the same power supply. In single channel or mono version, 100 or 200. With the 100, you can drive both channels to 1% THD+N before the supply runs out of steam. But with the 200, the supply runs out of steam first with both channels driven. So the ultimate setup is dual mono 200AS1's. This also allows to spread the heat more evenly across the amplifier case. Although these amps run super cool either way.
