ICEpower 125ASX2 BTL Board
Hello,
I want to use a 125ASX2 in BTL mode to power my subwoofer from my AVR via Chinch (unbalanced). However, from what I've read this requires a board.
Now I am wondering: Can I purchase this board somewhere? I can't be the only one in need for something like this 🙂
As you can tell by the question: I am a layman. I feel confident connecting a few wires (even with 230V) but not designing a whole PCB.
You can buy the ICEpower 50ASX2BTL board from Parts Express in the US, or Profusion in Europe -
https://www.parts-express.com/ICEpo...wer-Supply-Module-1-x-170W-326-214?quantity=1
https://gb.profusion.uk/uk/icepower50asx2-btl
Don't buy from eBay - I did, and the board failed to power up.
I trust you realise that in mono BTL mode the ICEpower's input is differential, so if your subwoofer output is single-ended you will need a SE-to-differential converter board. You can source this from many different places, but if you buy the Ghent RTX module -
https://www.ghentaudio.com/products/rtx.html?VariantsId=10801
then you can conveniently buy a suitable aluminium enclosure for your amplifier at the same time -
https://www.ghentaudio.com/products/a215-m1xr?VariantsId=18382
Reactions: asuslover and Soldy
I am probably not seeing it, but doesn't have the 50ASX2BTL far less power than the 125ASX2 in BTL mode (170W vs 450W @4Ohm)?
And from what I've read the 50ASX2 has a dedicated BTL board whereas for the 125ASX2 simply has "BTL" mode (where one input has to be inverted). And I might be mistaken, but doesn't it have unbalanced inputs already? Do I still need the RTX module for the 125 ASX2?
Also thanks for the safety tips 🙂
125ASX offers a BTL mode and for this it provides a differential input possibility but it requires that one of the input is polarity reversed. This needs an active board to achieve (or a traf.).
If you search eBay and AliExpress for "unbalanced to balanced board" you will find many options, including a basic NE5532 board for the ridiculous price of 3 Euros -
https://www.ebay.com/itm/175310519541
https://www.aliexpress.com/item/1005006578140837.html
But if you decide to order the Ghent case I would also order their "RTX" board, because $30 is not expensive, and I think the Ghent supplied cable kit should be plug-in ready.
Update: I see Audiophonics in France has 3x versions, from 10 Euros to 20 Euros.
Reactions: Soldy
Any of these should be able to do the job:
https://www.audiophonics.fr/en/prea...alanced-symetrizer-drv134-stereo-p-12571.html
https://www.audiophonics.fr/en/diy-...symetrizer-jrc-4580dd-btl-stereo-p-12296.html
https://www.audiophonics.fr/en/prea...ric-buffer-rca-to-xlr-xlr-to-rca-p-11661.html
You wan't to hook up the mono single-end signal from the AVR to one of the single-end inputs, i.e. L. Then you want to feed Vin Ch1 on the 125ASX2 with the Cold output of the corresponding diff L out and the Vin Ch2 with the Hot output of the diff L out.
Reactions: Soldy
