icepower 1000asp module modify?
mphi
2008-01-22 6:00 pm
I ordered the murno audio power amp which using icepower module.
How do you modify the icepower 1000asp module to become a high end amp?
What parts can modify and replace ?
Can modify icepower 1000asp outperform US $12,000-20,000 traditional class A/AB amp?
This a mains-powered high power class D amplifier, NOT A TOY. You are very likely to fry the module or youself if you either attempt the wrong modification or you touch the wrong place even when mains power is removed (capacitors may remain charged).
If you want a toy, either get one of those tiny 12V-powered IC class D amplifiers or play with class AB stuff, which is much more forgiving in case of any mistake.
