I plan to feed a SRC4192 from a MCU with I2S.
My master clock for the audio part is currently planned to be 24.576MHz. I chose this to be able to run the DAC with 128fs on the 192 kHz upsampled signal from the SRC4192.
Now I am wondering how I should clock the I2S signal that goes into the SRC4192 from the MCU. Does the SCK on I2S have to be a multiple (or even a 2^n factor) of the signals sampling rate (Fs). This would be a problem when having 44.1kHz Fs and only having a 24.576MHz clock.
Would I have to add a second clock just to create the SCK for the I2S->SRC4192 line in case of 44.1kHz playback?
