Hey guys.
So I'm trying to build a somewhat portable two-way stereo speakers.
Theese are the drivers I decided to use (yes this is a budget build):
woofer: tcp115-8 (dayton)
tweeter: nd20fb-4 (dayton)
I managed to design a pretty decent corssover design (i tried to get the flattest freq response)
Also I designed a suitable vented enclosure for the tcp115. Theoreticaly it should produce 50hz at -3db.
But I really cannot decide what amp i should use. It seems like the class D amps can sometimes have built in audio filters? is that true? maybe all of them do? this confuses me because i tried to design the flattest crossover design i could, just to know that the amp might alter the frequency response in the way that i would not like. i really have no knowledge about theese amps (not a great knowledge in amps in general) so i guess you can understand my confusion.
a single tcp-115 is rated for 40w rms and nominal impedance is around 8 ohms.
Do you have any class D amp reccomendations for this type of setup? budget options are welcome, links appreciated aswell.
Thank you.
Thank you.
