I-Mod POD 40GB
Hi people, I doubled up when doing a DIY iPOD line-out mod recently so I have one spare. It's been done with solid silver teflon and wired directly to the line-out pins.
Very similar to this but the headphone-out is left intact 😉
It comes with a Sync doc that has been modified with film output caps and I've built several SMD class D amps so all work is clean and tidy.
The Pod is Mint and it has a very strong battery.
Oh yes, it has Rockbox on there for playing FLAC etc, but can be reset to regular ipod if required.
Looking to see if there is any interest
Lee
Thanks, Lee. I have been looking at 60 and 80GB iPods lately, and frankly forgot that Red Wine offered mods to some iPods. I might be interested in yours if the price isn't too far off my budget. Keep us posted on offers that come in or total cost if you come up with one.
Thanks again!
Chris
Nice looking work! Will she still work with a stock iPod dock? Have you done all the same mods that Red Wine do? They seem to be the following (cut & pasted from their site):
The low quality stock SMT coupling caps after the internal Wolfson (before the stock opamp)
Opamp output stage
The low quality stock SMT coupling caps after the opamp output stage
The minuscule circuit board traces that carries the analog line-out signal
SMD resistors and inductors directly in the signal path
The signal path inside the stock iPod dock, which contains: the dock connector plug, a very cheap ribbon cable, more minuscule pcb traces, SMD resistors, and finally the line out jack.
Thanks!
