so yea as it says in the title old sub is broken and i have an old sony 8inch 4ohm subwoofer ,
thank u
thank u
Welcome to the forum!
3 ohm is not a standard nominal impedance for a subwoofer.
You may have measured the DC resistance of the sub with an ohmmeter, in which case the 3 ohm reading indicates a 4 ohm nominal impedance.
I don't know anything about actual impedance.
On the original subwoofer its written 3ohm
And on old one it's 4ohm..
What's correct way to check impedance
The 4 ohm will substitute for the 3 ohm as far as impedance goes, so you are OK to give it a try.
Impedance varies with frequency anyway and is not a fixed quantity. That is why, e.g., 4 ohm is only a "nominal" figure.
Measuring impedance is a more complicated procedure than simply measuring resistance with an ohmmeter, and isn't necessary in your case.
Iam little concerned about the amp exploding
I have a previous model with 6ohm subwoofer
I connected this (4ohm old sony) sun
The Class D amp chip exploded .
It was not over heating , it shorted .
I don't want to happen again ...
Either I'll get a 8 ohm sub or use the old sony sub
Iam hoping this time
The 4ohm sun won't hurt 3ohm amp ..
Does lowering power to -1db or -4 db reduce the probability
A speaker of higher impedance keeps the peak currents low and is therefore less likely to damage a Class D amplifier.
Similarly, lowering the dB level also helps protect the amplifier.
Connecting a 4 ohm subwoofer driver should be marginally safer than connecting a 3 ohm subwoofer driver.
However, for all I know, your 4 ohm driver could possibly be short circuit, explaining why it damaged your previous amplifier.
Measure the DC resistance of the 4 ohm subwoofer with an ohmmeter to eliminate that possibility.
