Hurst LYD350241 Permanent Magnet Synchronous AC 24V 4 watt motor for DIY Turntable
I bought below motor for diy turntable. We have 220 volts 50 hz electric at our home . What would be the wall plugged adapter specifications , they have high watts. Can I use them ? What are the margins ? Is there any good source to buy an adapter online not expensive , 20 $ or less.
Is that motor usable with belt or is it direct drive ?
What is the easiest way to synchronise it , would it be a mp3 player ?
Do you have mp3 file you can send to me ?
How I can lower the speed ,with mp3 ?
Umut/Istanbul
Torque
(oz-in) 2.3
Torque
(mN-m) 16.2
Output
Speed
(RPM) 250/300
(50/60 Hz)
Input
Power
(watts) 2
Nominal
Voltage
(Vac) 24
(50/60 Hz)
Winding
Res.
(ohms) 316
Rated
Ind.
(mH/phase) 0,368
Capacitor
Value
(mfd) 4
Length
(L, in) 0.866
Length
(L, mm) 22
Weight
(oz) 3.76
Weight
(grams) 100
