I did a search and could find anything that could help my situation.
Anyway,I have built a line level preamp using 6SN7's,and I have built this amp with a solid state external power supply,and it has worked great,very low noise that was only audible with the gain turned all the way up,and then it was just a slight buzz,well I decided to go with a tube based power supply using a 5AR4,I plugged it all in and powered up the preamp and then the amp and right off the bat, a very noticable hum,even with the gain turned all the way down on the preamp. I disconnected everything checked my voltages and everything measured just fine,I checked for possible ground loops in the preamp and none could be found,I'm at a loss as to the problem.
The power supply consists of a 275-0-275 50mA transformer connected to a 5AR4 rectifier it then passes through a LCLC filter consisting of a 2- 47uf 450V capacitors,and 2- 15H 30mA chokes which then passes on to 2-12K ohm plate resistors connected to 2-100uF caps,and also I am using a DC supply for the filaments.
Denny
Denny
