Hello All,
Basically I have my setup as this: The cable tv coax runs into my vcr, which runs into my amp via RCA cables. The problem is this: I get a very loud hum! Its terrible. Anyways, this only occurs when the cable TV is plugged into the vcr. If I disconnect TV, the VCR outputs no hum at all. I was wondering if I should short the cable tv earth or ground to the case of my amp, or if this isn't a good idea. Any help greatly appreciated.
Pete
Pete
Try this web site..
Go to:
http://www.smr-home-theatre.org/Ground-Loops/
Read the whole article.
It gives a good explaination of what causes hum. Look farther down and you'll see Cable TV recommendations etc.
Go to:
There are small small isolation transformers available mounted on TV coax cable. Just to plug in between your VCR and incoming TV-cable. Works fine, I've got one myself. Buy from your nearest electronics supplier. Costed about 7 euro.
