Hi everyone, I'm having trouble setting up the processor for my tham 12 with beyma 12lx60v2.
I use it on a channel of the m50d old version-no-dsp (750w) amplifier, and I can't limit so that the red LED doesn't light up!
I use a t-racks DSP 4x4 Mini , and I set a 40hz high pass, and a limiter mode compressor:
4ms connection
reposition 128ms.
but any value I put in db, even -10db, (amp gain 32db) raising the master the final goes to red anyway! something that does not happen with installations that I use in the premises (normally they use xta) where even saturating the mixer (a practice that is not correct but I want to be sure of not doing damage if I get distracted when I play) the ending never goes red even if the limiter is red steady !!!
regards
4ms connection
reposition 128ms.
regards
