I really enjoy as hobby to restore old amplifiers. As electronic engineer, I can deal with most component as well as mechanical issues. However, I still have not found solution for broken PCB. So, hope to find some advice here.
Issue is, some of the old PCBs use such poor "glue" of the copper layer to board, that when even slightly overheat or slight mechanical damage directly remove pads for component pins go out of the PCB. See this issue for example for old Rotel amplifiers.
I’m trying to be precise as much as I can, but with some components, that has mechanically pins bond over, and the pins need to be straighten before component can be pulled out, on such type of PCB it has become nightmare.
Even be really careful, cause me usually at least one pad goes out of the board.
Many people would just scratch the PCB to bare copper next to pad, and solder the component there. But I would like to fix the PCB as much to original as possible.
I have tried to make new pads of same shape and size from thin copper foil. Which works quite well. And then I try to look for proper glue to make it stick to PCB as much as original or even better. Trying to find the glue, that can be resistant to common chemicals like alcohol, solder flux and such and can take heat up to needed soldering point (300+ degree of Celsius). Glue should be ideally transparent, so when little stays around pad, it’s not optically noticeable much.
I have tried multiple different epoxy glues, looking for specific high temperature ones. Tried different brands, some specific heat resistant or some sort of green non soldering film type. All of them failed to stick well or survived 2 second soldering.
Do you have any suggestions what glue to use? Or what is your way of fixing broken pads? Any advice appreciated.
