To flush mount round drivers you will need to buy or make a circle Jig.
You'll need to measure the radius and depth of the cuts, then set up the depth on the plunge router and the radius on the circle jig.
Then you drill the center holes, then do the cuts.
I use a home made jig but they are also available at parts express. The Jasper jig is quite popular.
Grahamt said:To flush mount round drivers you will need to buy or make a circle Jig.
i have the jasper jig
straying from ca.com are we thylantr?
Grahamt said:You can use the straight bit if it is wide enough. I have a few, I choose the appropriate one depending on the mounting flange of the driver I'm using. A 1/2" bit is probably good for most drivers.
- how to flush mount
