Hello,
I hope someone can help me out, I would like to change the phono input's capacitance of my Rega Brio r form its standard 220 pF to 47 pF as this figure would better suit my Ortofon 2M cartridge, but I don't have the slightest clue on how to do this...
Do you know if it's feasable and/or there are potential issues that may arise from doing this?
Do you have a schematic for the Brio r?
Could you please walk me through this? I have only ever soldered cables and I'm not in the least competent, do you think I should avoid doing this myself?
What parts should I use for best results? I don't mind employing boutique capacitors if it's worth it, I was told I should be looking for a 47 pF 'COG' ceramic cap.
Thank you very much for your help!
Without seeing the circuit we can't give specifics but essentially you are looking at replacing a capacitor that will already be present on the input to your desired value. This capacitor will be "across" the input to ground.
Maybe post a clear picture of the internals of the amp around the phono stage for starters
Thanks, I was actually going to gather as much info as possible at this stage because I don't have the time and the equipment to perform the operation at the moment, but I will try to post some pictures in the mean time.
I read that lowering the capacitance can make the phonosection more sensitive to RFI, do you think this might be a problem given the Brio r is an integrated?
