Hi guys,
Quite a basic question, and I have read a few posts on it - but I am a bit of an elctronics novice (to say the least!).
I intend to buy myself two mono Hifimediy T3 amps soon and package them into two separate cases to give me two nice monoblock amps. The amps come with single ended inputs. I would very much like to have both balanced and single ended inputs to them. Firstly because I am not yet sure whether to place the amps near the speakers (requiring long runs of wire that will pass the 220v AC power cables that power my tv/digibox/etc) and also because I intend to use the balanced version of the minidsp. There is also the possibility I will get a DCX2496 instead of two minidsp's, or indeed a different DSP altogether to act as an active crossover.
Is there a product or simple way that I can add both inputs to the chassis, possibly with a switch to select which one to use? I have seen examples of this on other peoples amps, but am not sure how they have done it.
I know I can wire the minidsp to run single ended output, and probably will do that to get myself started.
If it is completely pointless I guess I wont bother, so look forward to your input..
Many thanks!
Regards,
Jai
Many thanks!
Regards,
Jai
