I'm only asking because I don't know. Everything has a breaking point, I want to make a 10w set (dual mono's), but am worried that due to spl something bad might happen to the tubes...
If your SPL is high enough to damage tubes, your eardrums would have already departed, mooting the issue.
The main concern is microphonics, that is, a tendency of some tubes to act as vibration sensors and hence cause undesired feedback at certain frequencies. If you keep your amps behind your speakers or several feet remote from them, you're unlikely to have an issue unless you have some really poor tubes in it.
as far as I remember low bass does not hurt your hearing like high freq. Most of my spl has to so with a ton of low.. Yes the highs make my ears ring.. Everything has a resonate frequency, my 2500 sq ft house as testament. It really feels like it would break the filaments, I can't even see straight typing this....
A 10W amplifier shakes your 2500 sq ft house foundations and walls so much that you almost can't type?
Amazing.
Unlikely. I've never lost one this way and my system does not lack for lows... Remember, there's lots of tube bass guitar amps out there.
Sorry for the bad reply, Im running peak bass of 6000+ watts in my basement (10x20ft room). I honestly at times sucks the air out of my lungs and I have to leave. It shakes you so hard you cannot type. I apprecieate the response, so Im good!
I didn't know they had a limit, thanks!! I'll make a 10w set dual mono.. I've been cars at 140db, this setup you cannot compare, way more. My printer almost fell off of my desk, and those svs's walk off, yep 100# and they leave the ground and wander. I appreciate the help, another project 300 tubes...
I can actually feel the boom boom 100 ft away outside the house with the windows closed. My neighbor called me more than once to complain... Im in the basement, not first floor.. Feel it...
What I do have is insane, why I asked the question, well My body can't take it, I don't know if a tube can. I can't breathe ttyl
I've been to a lot of concerts, been in many a comp car, I'm worried for the house. It's that sic and good, you just don't want to spend any time in the basement, maybe outside....
I can help, sharing like MR Pass does is the only way to leave a legacy, and continue the tradition. Blurrrrrr, sorry jammin''I hope one day to own a system that's so good it makes me run from my house.
It's just that these speakers and amp gel well it sounds natural, but LOUD! and clear too.... even from 100 yds 😉I hope one day to own a system that's so good it makes me run from my house.
In all my years I have seen exactly one tube damaged by "sound."
We lived near enough to Homestead Air Force base to experience several sonic booms per week from the F104 Starfighters cracking the sound barrier in the 1960's. One of my neighbors who was in the US Coast Guard said his TV died at exactly the same moment of a rather loud sonic boom. Autopsy revealed a broken horizontal output tube.
Any directly heated tube has a rather fragile filament, thoriated filaments become brittle with repeated heating and cooling cycles. It may be possible to break a DHT filament with excessive bass, although I have never seen one. I have been known to play my guitar through a 300B amp, I won't set that amp on top of the speaker cabinet.
I love the wit and humor, really I do. Those glass thingys look like they need a warning label. I've tried to blow this whole thing up many times over just to prove it's rock solid, I guess it is. The other thing is, according to my kill-a-watt meter these subs are not running up to spec, maybe it's a good thing. The most I ever saw on the imput side was 575w. I am only running them with variable preamp out from my denon cd. I know I don't need more those things are scary......
I'll never forget a good friend Mr. Smith, who passed away many years ago. He was an electronic guy who had some neat stuff. A tube repair machine? An old one, it puzzles me to this day how it really worked, I have no clue. I should have helped his wife sell that beautiful mint maranz 9, and he had speakers the size of freezers that he said had 24" woofers. I think they were electrovioce if im not mistaken, Huge. They were all impressions with 20/20 hindsight. I didn't know audio like I do now or I would have bought everything for a grand....
It's all subjective, it's what you want. I get a kick out of those pc13 ultras. Those little 13.5" drivers each weigh 60 pounds..
Given some guitar amplifiers have the valves just above the speaker then its unlikely you will have any problems.
Personally I hate combo amps, I prefer separate amp and speakers so the speakers don't vibrate the amp to pieces.
How is that for a contradiction !
- Tubes / Valves
- How much spl can a triode take?
