Or should I ask How close can one sit to multiway horns and have them gel in a fairly coherent way? I'm trying to figure out what I can fit in my room. Actually having built them, but not yet been able to fire them up, I'm wondering where I can fit.
Lower mid horn is 950mm wide and covering 250hz-1k. Mid horn is 450m diameter and playing 1k-8k, tweeter above. They are all on the same vertical axis squashed as close together as possible which leaves about 700mm between the axis of the bigger two horns. Is there any rule of thumb about driver spacing and listening distance?
Is 3m across the width of the room too close -do I need to be considering firing down the length of the 12m room instead....? (give up a nice view and a fair bit of bass this way)
Thanks for the help
B.
Thanks for the help
B.
