How are pressfit tweeters installed?
So if you have to bore a hole through it would there be holes on the front where I mount a rear firing tweeter since this is open baffle?
The title of this thread made me laugh 😉
Depending on how thick the baffle is, yes. You could make a small added thickness baffle or just glue the tweeter to the back. Diffraction probably doesn't matter for a rear firing setup.
