Horn with no LF limitation !
LISTEN TO WHAT YOU’VE BEEN MISSING.
Active horn subwoofer PULSE is designed to reproduce the first octaves of the acoustic spectrum in large rooms without any limitation.
Seems like BS to me, if they mean circa 20Hzish !
The horn, tuned to the lower acoustic limit, fires to the floor and loads a 15” woofer. ?t’s full length is braced to avoid any colorations and it’s build of grade A Baltic birch plywood. The embedded -more than adequate- 100W switching amplifier will reproduce a max spl of about 130db depending on placement.
TUNE AUDIO PULSE | LISTEN TO WHAT YOU?VE BEEN MISSING. MUNICH HIEND 2011 TUNE AUDIO LAUNCHES PULSE | TuneAudio
