djQUAN said:either way is good. but my personal preference is wire each coil in series so that each sub is 8 ohm then wire both subs in parallel to get 4ohms then bridge the amp.![]()
That is the best way. You will also be running higher voltage so it will be easier on the speaker wire.
At work, when running a two channel amp, we always avoid paralleling the coils and running 2 ohms stereo for customers because they could try and change the amp from stereo 2ohm mode and try and run it at mono 1ohm and cause issues. 8ohm at the box terminals means they could never run the amp at too low of an impedance.
