I was wondering if anyone has done anything with the LM3875 chip for making an amp.
I thought it would be pretty simple to do this, but I need some rather newby help. Can someone explain what type of power supply I should use with this chip and should I use the typical application schematic?
I appreciate any help that anyone can offer, please share your knowledge
If anyone can almost spell this out for me that would be great.
You can search the forum for info on using this and similar IC's.
http://www.diyaudio.com/forums/search.php?action=showresults&searchid=44556&sortby=&sortorder=
Try this link
Try this link
Welcome to the forum!
There is a good thread here on the LM3875:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=4999&highlight=LM3875
I found this by using the search engine. You should try it and you might find more useful information.
Good luck in your projects.
Brian
Brian
syko82,
Try project19 http://sound.westhost.com/project19.htm Its got very few components and sounds good. For the power supply I am using Avel Lindberg 100va 25-0-25 toroid, bridge, and two 10,000uF panasonic caps. I am building two more channels and going to try bi-amping my speakers.
Also consider getting circuit boards from Rod, he is very helpful.
Hi syko82,
Be sure to visit the Amp Chip DIY board here. This board specializes in amps based on IC's like the LM3875 and LM1875. I have built a stereo pair based on a design similar to this one, and it is currently my favorite amp.
It's an easy, fun, and cheap project that gave me great results!
Good luck.
-f4
Good luck.
-f4
I use one 100va for 2ch circuit, two toroids total. According to www.avellindberg.com the secondary current is 2 A. I am using AVEL p/n Y236404.
I used one 225VA 18-0-18v Plitron transformer to power two LM3875's, but that is probably overkill.
You might want to try www.apexjr.com under the Miscellaneous category for cheap toroids. They have a 120VA 18-0-18v that is really inexpensive, but I wouldn't use more than two chips per toroid, IMO.
-f4
-f4
- Home Amplifier Help
