Let us know if Electronic Transformer Co. (Freed) will make those Cit II Ots still. Might even get a volume order together here.
How about the Freed # for the Citation II power transformer?
(assuming they made that too) Might as well get the whole setup.
I would also suggest asking Electronic Trans. Co. if they could increase the 6.3 VAC winding current rating a little (another 0.3 Amp). Could use 6197 tubes (0.65 Amp htr.) instead of 12BY7 tubes (0.6 Amp htr.).
One less than the output transformer, FT3273670.
The choke was one more, FT3273672.
I'd guess these parts and numbers were made for HK all at the same time, so are consecutive.
Harman Kardon Citation II - Manual - Stereo Power Amplifier - HiFi Engine
Well it never hurts to ask.
But it looks like they don't have the information on the old HK numbers.
They do however have the ability to make the iron listed in their catalogs.
So if you look here> http://bit.ly/2LdhhnR
Those are readily available.
I ordered a QGA-42 which is a 100 watt 5K ohm output transformer and it looks great !!!
- Tubes / Valves
- HK Citation II
