Hi there.. I have just made the http://www.zaphaudio.com/audio-speaker18.html and now i got a hivi m6a unit i want for a little sub, but im not quite sure about box volume and vent size...
and can you reccommend a diy active crossover to use with it... it should go from 150hz and down.. right??
Rod Elliot has a design for a Linkwitz-Riley 24dB/octave 2 or 3 way crossover. He can supply circuit boards if you want to do it easy...
http://sound.westhost.com/project09.htm
Collo
Collo
At the bottom of the page for that project is a downloadable calculator to let you pick the components for whatever frequency you need to cross over at.
About the middle of the page are the formulas
Collo
Collo
- Subwoofers
- hivi sub...
