Hey Guys,
I am going to rebuild my 845 monos, and would like to eliminate the electrolytics in the power supply. I need caps that can handle 1000-1200 VDC. I am familiar with the ASC oil-cans, but they do not seem to have the voltage/capacitances in need.
Jensen seems to have some high voltage metalized caps, but I question the availability of these products.
So, any suggestions?
Thanks,
Bryan
Thanks,
Bryan
Well, I am currently using a stack of electrolytics to give me 100uF at 1000V, so in the "ideal" world, I would want a 1000-1200 VDC/100uF cap.
Thoughts?
BK
Thoughts?
BK
I have a couple of PP in nitrogen caps you may find interesting.
http://www.briangt.com/gallery/magura/PICT0001
Those are 167uF 630V, so 2 of those in series should do the trick.
I also have a few PP in oil caps of 55uF and 167uF 630V laying around.
Magura 🙂
Magura 🙂
Nice looking caps... Where did youu source them, and what are they worth to you?
Do you only have the two, as I ultimately need the equivalent of 2 X 1000-1200VDC/100uF caps, one for each channel.
I have a handfull of each.
They have been saved for me and my closest friends projects, unfortunately my wife is of a different opinion, so now I have downgraded the demands to selling them to somebody whom will actually use them, as I don't want to see them end up in somebody's pile of collected parts he "just could not live without".
I bought them from an old friend of mine whom ultimately had the same issue with his wife.
Magura 🙂
Magura 🙂
Firstly, is the wife tired of the projects in general, or just projects of such high voltage/consequence, and secondly, what do you want for the caps?
I'm fortunate the my girlfriendf is quite understanding of my hobbies, and lets me fiddle as I feel necessary. She doesnt understand it, but likes that they make me happy.
This is not to say I can ignore her. She is a firey italian woman, and lets me know when she needs attention!!!
I've dodged a few flying plates, and thus have learned my lessons...
Anyway.... back to caps.
Are they super expensive? My 845 monos would make a good home, no?
Bryan said:Firstly, is the wife tired of the projects in general, or just projects of such high voltage/consequence?
Naah, she even participates in building amps. She just don't like the amount of heatsinks, resistors and caps in the livingroom, to be honest I kinda understand her, it have been getting a little out of hand within the last year or so.
Magura 🙂
AC motor run caps are rated at least 1.4 x AC rated voltage. 450 VAC = 630 volts DC or 370 VAC = 518 volts DC. Use two caps in series.
Review this after you get married !😀
I am aware about the series application of the caps, but if I were to do so, the highest value I can source is 60uF. In series, two caps would only give me 30uF, and I am looking for something in the 100uF range....
Thoughts?
BK
Thoughts?
BK
88uf 1200VDC
Look at the surplus sites for these 88uF 1200VDC caps. Everyone was selling them for a while. I bought two for $14 each from Herbach Rademan a few years ago. Beware the cans are square and about a foot high with inch long ceramic terminal lugs. That or you can series wire 600v motor run caps. I bought the giant caps for power supply testing. Its nice not having to worry about exceeding the voltage.
Just watch the terminals. Shorting a fully charged one would probably melt a screwdriver 🙂
I have a friend who works in the medical equipment repair field. He has become an excellent source of high voltage caps. There is a lot of old equipment that is no longer certifiable for use in the USA. Much of it is exported (to the Caribean) or used in veternary medicine.
Two good sources that do not get used in veternary medicine are electrosurgery machines, and defibrillators. The cap in my 845SE came from an electrosurgery machine. It is 4uF 2500 volt. The cap that is going in the 833A SE is 16uF 7.5 KV. Both are paper in oil. Some defibrillators had 30uF at 4KV caps. Often these machines can be purchased for their scrap value. I got buth machines for $10. The electrosurgery unit had 2 813 tubes in it. The defib caps are rated for pulse discharge and thus have a low ESR, and a low inductance. This makes them excellent for tube amps.
I use electrolytics for the input cap and PIO caps after the choke. This is a good compromise.
I've been onto that... Looking at the defib caps. I can see that Aerovox has some, but if will I be able to get my hands on them is the question.....?
I'm running 900v anodes, on my 805 monoblocks and have found JJ caps great, and also sounded better than the Nichicons that I removed, check the link below, and they are very good value if purchased direct from JJ Canada.
http://www.jj-electronic.com/pdf/TC_TE.pdf
Cheers George
Cheers George
- Design & Build
- Parts
- High Voltage Power Supply Caps
