Hi all.
I'm starting to think about new projects to occupy me over the winter. I'd like to build low powered SET amp and also a phono stage.
My (DIY Lenco based) turntable can accommodate up to 4 arms and carts at the same time. To make the best of things I need a phono stage with 4 inputs. I'm not able to design electronics but can follow instructions, solder and build things. I'd like some ideas please, idealy links to phono stage kits I can buy and adapt to include a switch and 4 inputs. 4 x MM is fine as I'll use SUT for my MCs.
So far I've found and like the look of this (should be possible to add more inputs and a swtich) VS Phono Stage with LCR Modules (kit)
Please post links to any more high quality phono stage kits you know of, valve or SS
Thank you very much.
Graham
Graham
