On this amp I'm not getting the +15 volts on the opamps..
I checked the 7815 and it tests good
I also checked the 7805 and that tests good..
On the output leg of the 7815 and the 7805 in getting -1.02 volts
Any ideas what might cause this or where to check?
I've been checking components and everything is testing fine
You can try it but it's likely to burn out. The larger one can likely handle much more current.
If you have a 1/4w, 1 ohm resistor, you can use that temporarily.
I used the smaller package style for testing and the 15 volts is back ..
I will order the correct package size ..
Thanks for the help
Thanks for the help
- General Interest
- Car Audio
- Hifonics BRZ2100.1D
